Haltech E6s vs E6k
Old Mar 20, 2007 | 09:55 PM
rx7legend's Avatar
Fc3s 4 life
E6s vs E6k
hi, sorry if this has been discussed like 50 times but i want to know what's the difference on this 2 ecu's, im looking to buy a standalone and this computers are on my reach but being the E6s the previous version of the e6k(i think) i want to know what are the differences and if i will have no problem if either i stick with the E6s or E6k.
thanks for the help
Old Mar 20, 2007 | 10:21 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
thanks for the help
The main differences between the S and the K are:
1. K has better comm speed
2. K has faster processor (i think)
3. K has 4 PWM outputs the S doesnt
4. K can be configured completely through software, the S has to be tweaked through dip switches and jumpers in the board.
So, there you go.
K technically is better, BUT!, the S will work just as good, minous the additional features.
Old Mar 20, 2007 | 10:26 PM
slo's Avatar
slo
registered user
Doesn't the S lack an internal reluctor adaptor
Old Mar 20, 2007 | 10:56 PM
rx7legend's Avatar
Fc3s 4 life
So, there you go.
thanks man, it seems there aren't that different, i think ill stick to the e6s since im getting a price i can reffuse.
thanks
Old Mar 20, 2007 | 11:07 PM
EFI Tech Wannabe
Nop, it did have it, but you need to really know what to do to make it work right, you have to tweak the jumpers and dip switches inside the ECU.
Although from what i know, its only on the last production runs of the S, so, maybe the last 1000 units to be made worked with most ignitions?
I've installed a couple of S so i can tell you it does work when set right, its just like playing with the Gain settings in the X or K software.
Old Mar 21, 2007 | 08:15 AM
RETed's Avatar
The E6S has a questionable internal reluctor set-up.
I've never heard of people having too much luck with the E6S with RX-7 stock ignition triggers.
We've always had to resort to a pair of MSD 8509's (ala E6A).
It's worth it just to go with the E6K cause of their internal reluctors, since the E6K internals are rock-solid with the RX-7 ignition components.
-Ted
Old Mar 21, 2007 | 01:09 PM
EFI Tech Wannabe
-Ted
I dont want to turn this into a pissing contest, but i have used the S with its internal reluctor properly dialed in on 2nd GEN CAS, and it works perfectly. But like i said before, that was on the last production firmware for the S, something like the last 500-1000 units. But it DOES work.
At any rate, the MSD8509 boxes do provide a much better, more compatible hall effect signal for the haltech to read from.
Its like the thing with the X in the begining, people were setting them up as if they were Ks and that just cause a whole lot of problems. Its the same thing here, when properly set they will work perfectly.
Old Mar 22, 2007 | 06:43 AM
RETed's Avatar
Nah, not a pissing costest.
The added info is always welcome.
You're right.
The E6S boxes we messed with were very early production #'s.
It was easy to install the 8509's since the cars already had a previous E6A installed.
Our initial tries with the E6S internal reluctor was pretty bad.
-Ted
Old Mar 22, 2007 | 09:34 AM
EFI Tech Wannabe
You're right.
-Ted
No worries man, my very first install was an E6S on my personal FC back in 2000, i had to use the 2 MSD 8509's cause i didnt know about the internal reluctor, and 3 MSDs since i didnt know about using the stock igniter method either, which it could do. We spend 3 days sorting it out and calling people back and forward. Turns out my old S could've been installed without any of those things since it had the appropriate firmware, but such is life, you live you learn.
Old Dec 5, 2007 | 06:35 PM
denver's Avatar
i need two o three msd 6a boxes?
Old Dec 5, 2007 | 08:50 PM
Snack's Avatar
Panties Explode
not 6al ignition boxes.... you need 2 MSD 8509 boxes. They dont do anything but change the wave from the cas to the "Hall Effect" wave. Just msg me if u get the boxes with e6s. I can help you wire it up.
Old Dec 9, 2007 | 01:12 PM
EFI Tech Wannabe
Ideally you will need 2 MSD 8509s, or one RA10 Haltech reluctor adapter. And i just did this recently with an S i had lying around and found out that you can trigger the stock igniters with it, it didnt have the Constant Charge setup work right, so to fire your RX-7 properly you will need to have 3x MSD 6A ignition boxes for that to work. I had that on my car years ago and it worked fine, its just a big demand on the electrical system on those cars.
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
VtekEater
Engine Management Forum
Oct 31, 2001 11:33 PM
