BBS 16x9
1 Attachment(s)
ok i have a set of 4 of these bbs 16x9.
Im looking to put them on my second gen vert that has f & r eibach springs. they came off a second gen coupe so i know they fit. my question is iam I able to run 225's on these rims up front? will it except the 225's? can i use spacers on the 16x9 with 225's up front? or should i go with 205's up front and 225's in the back?:scratch: |
I run 235 on my 17x9 but they are ad08 so they are more like 240
rims
well I put the 225's on the driver side front and it wouldnt seat right against the hub without the spacer.
I dropped the car down with the 225 up front onto the ground and It went down without a issue. It just felt real close to the strut and didnt want to cruse with these and hit a bump and .blow out a tire so thats why I ask if anyone is running 225's on the front of there 2nd gen. |
https://www.rx7club.com/suspension-wheels-tires-brakes-20/official-fc-wheel-fitment-thread-257700/
offset... I run 17x9 235/45/17 up front but that means nothing without offset. Ride height is a unique thing and we can't tell you "yes". It's a test and change height to make fit thing. |
Thanks mane^^^^
ive got 225 RE-01s on all 4 corners currently with a spacer. JIC coil overs.
I can check my offset when i get home, but i have 225/50's on my 16x8's in the rear with no problem, then 205/50 on my 16x7'x in front and they dont rub.
16x9
The rears Im not seeing any issue with it possibly rubbing, only the fronts seemed close.
I threw a 5/16" spacers on front with 225 50 16 tire and i just seemed really close between the strut and eibach springs. Im not sure what the offset is. |
