83mm or 87mm Turbine Housing?
Old May 15, 2012 | 11:35 AM
Alpha-7's Avatar
Lightbulb 83mm or 87mm Turbine Housing?
How much of a difference does it make really?? is it worth the extra 350 bucks? street car with half bridged cosmo .. Bw 372 or 375 leanin towards s375.. any input thanks
Old May 15, 2012 | 11:20 PM
Cosmo_TT's Avatar
BRAAAAAP pssh BRAAAAAP
is the 375 just the T4 version of the 475?
Old May 16, 2012 | 06:43 AM
Alpha-7's Avatar
believe so
Old May 16, 2012 | 09:11 AM
mono4lamar's Avatar
In the burnout box...
If it's a street car you'll never take "advantage" of the 87mm wheel. I've built three s375 turbo kits for customers and they have all had great results with the 83mm wheel. Don't over think what doesn't even make sense here...
Old May 17, 2012 | 08:26 AM
mono4lamar's Avatar
I got a couple PM's as far as fitment. Pay a professional to build you a manifold. You'll even be surprised how many "professional" turbo kit companies manifolds require you to modify your chassis or motor mounts to fit. Anyway here's a lager frame turbo and the tight area you have to deal with...
Old May 22, 2012 | 09:27 PM
ALNY93R1's Avatar
That kit is looking sweet!!!
Old May 23, 2012 | 08:04 AM
mono4lamar's Avatar
^ It's going to a great guy that will probably have a broken neck when he hits full boost
Turblown
Vendor Classifieds
51
Nov 23, 2018 10:52 AM
