Brake Fluid: Endless RF650 vs. Motul RBF600
Old May 11, 2012 | 08:32 AM
curacaosfinest's Avatar
1.3 Liter V8 Eater
hey guys,
so i'm going to be installing my StopTech BBK up front soon
my car will be used for mainly street and some track purposes
the 2 brake fluids i found that are getting the best ratings are the RBF600 and the Endless 650
i've used the RBF600 on the track a lot before and loved it, but it seems like the Endless is doing really well now
what do you guys recommend?
thanks
VJ
Old May 11, 2012 | 11:07 AM
Brekyrself's Avatar
Community Builder
I recently switched from super blue to Wilwoods EXP600 and have not had any boiling issues at the track. I also run Ti backing plates front and rear to keep the heat out of the fluid. I run R Comps with DTC60's so these stock brakes are seeing some high temps
You probably can't go wrong with either for dual purpose. Just flush it every 1-2 years, leaning towards yearly if you do a lot of track events.
Old May 11, 2012 | 12:18 PM
Scrub's Avatar
bow leggin'
Endless RF650 all the way. The fact that ALMS Porsche factory cars switched from SRF to Endless is enough for me. If you'd like more technical reasons I can write them out. RF650 is also being used in Formula 1.
In all honesty though, you're probably not going to have to worry about boiling fluid since since it's mostly a show car.
Old May 11, 2012 | 02:58 PM
Narfle's Avatar
Rx7 Wagon
If Brekyrself can run RBF600/EXP600 and not boil the fluid at the track with stock brakes, you ought to be fine with either one.
I'm running RBF600 on the streets with Endless MX72 pads, and I can't get the brakes to fade coming down the mountain. FWIW.
Old May 11, 2012 | 06:13 PM
1.3 Liter V8 Eater
the car will be more on the track than on the street, only at shows that are required for the sponsorship i got for the StopTech brakes
i think i'm going to go with the RBF600...its a lot cheaper than the Endless so i'll just change the fluid more often and if i boil the 600 then i'll move up to the 660
Old May 11, 2012 | 09:29 PM
MisterX's Avatar
I went with Endless S Four last year as I don't run on the track; although I get into the triple digits quite often on the street. Before that I ran the Motul 600. From the reviews and testimonials Endless looks like the superior product (even over SRF), though that applies to the 650, which must be changed at much shorter intervals vs the S-Four.
Old May 11, 2012 | 10:17 PM
my FD rolls with Fikse, Nardi and Endless
chiefmg
Sep 10, 2015 07:46 AM
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
