Microtech Ignition cut?
Old Apr 17, 2012 | 11:40 AM
Samito Built's Avatar
FL Ignition cut?
When my ecu was ordered from microtech it was specifically ordered with igniotn cut instead of standard fuel cut. So when i used the rev cut option its cuts ignition instead of fuel. All ecus that kilo racing are ordered are like that. So my question is their a way you can check in one of the screens on the microtech to determine which one do you have?
Old Apr 17, 2012 | 03:25 PM
rxspeed7's Avatar
F-IT
Not that I'm aware of. Set up the limiter at like 2k rpm and hook a noir light up to the inj and see if they stay light or if they go out
Old Apr 21, 2012 | 05:14 PM
flaco's Avatar
Originally Posted by Samito Built
I was thinking the same thing
yes just like he said . also if it says ignition cut should be what it says
Mps_hell
Sep 19, 2015 10:02 PM
Donald Hampton
Sep 17, 2015 03:13 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
