Car start problem
Old Apr 12, 2012 | 11:56 PM
hien3000's Avatar
Own 87' Mazda Rx7
TX Car start problem
i have a problem with my engine turning over. all i hear is a click when i go to crank it. yes i have a brand new starter and solenoid,i check the battery cable for any soft bumps or tear, the battery is new, brand new battery terminals. yes, i took the brand new starter and solenoid to be tested and it passed. i tried to turn it over once and cranked but very weak. but only once though after that just a click. probably some of you guys are experiencing what i am. just need some help with it.
Old Apr 13, 2012 | 06:14 AM
Sorrox Bluefield's Avatar
MO
Well I just had the same thing happed to me after I done a JDM Turbo swap in mine and after I tryed to start it i herd a clicking sound to but found out that the main ground was not hooked up to the start and then she started just fine.
Check to see if your main ground to the start is hooked up. if it is then its a ground in your wirring to the batter to the starter somewere that what i was always told.
Old Apr 15, 2012 | 02:28 AM
hien3000's Avatar
Own 87' Mazda Rx7
better than nothing. before when i had the old starter it cranked really slowly, hard starts as well.ill check it out tomorrow and get back to ya. thanks for the reply or else i wouldn't even think about the main ground ^_^
Old Apr 15, 2012 | 07:12 AM
Ya i did not ether my self when i got everything hooked up and tryed to start nothing just a buzzing sound and could here the fuel pump lol so i checked what i missed and there it was and then she started right up.
Old Apr 15, 2012 | 07:15 AM
Landon303's Avatar
sure the clip on female ground is attached to the starter?
Kyo
Apr 13, 2019 09:24 AM
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
torky007
Aug 17, 2015 05:14 PM
