How much boost with "modified" stock exhaust?
Old Jul 24, 2002 | 05:12 PM
Barwick's Avatar
SCCA Rookie
Surely you all know the history of my car by now.. only boosts to 5.5psi then slowly goes down.. it seems that one or the other of the cats are clogged. I'm guessing it's the main cat. Took it to a muffler shop, told him "I think the precat is fried and broke up, throwing itself into the main cat and clogging it up". He said he could fix it with a straight pipe for $30 (good deal in my opinion, pretty cheap
Anyhow, assuming the precat is TOAST, and the main cat is no longer existant, how much boost should I be expecting now after the main cat is gone (and no longer clogged I guess).
Old Jul 24, 2002 | 05:42 PM
It depends on the diameter of the pipe but with a 3" one(which is what you should get) and everything else stock, I'd say you should see... about 8 psi when it's cold.
-Colby
Old Jul 24, 2002 | 05:54 PM
NZConvertible's Avatar
I'm a boost creep...
Re: How much boost with "modified" stock exhaust?
Originally posted by Barwick
...how much boost should I be expecting now after the main cat is gone.
I have no cats, a 3" cat-back and a pod filter, and see 8psi.
Old Jul 24, 2002 | 05:59 PM
jimmyv13's Avatar
Round&Round not Up&Down
I have 2.5" DP, gutted main cat, 3"TID, and cone filter and I see 8 sometimes 9 PSI.
Old Jul 24, 2002 | 08:07 PM
Barwick's Avatar
SCCA Rookie
sweet.. I was thinking that I would be closer to like 10.. good thing I'm not cause I just want it to RUN.. not run super super fast.. I don't have the $$ to upgrade the fuel yet.
streetlegal?
Mar 17, 2022 02:46 PM
cristoDathird
28
May 30, 2019 08:47 PM
