Is "Something" sticking (BOOST TRANSITION PROBLEM)
Old Jul 24, 2002 | 05:05 PM
BigRed's Avatar
Alright. this situation has been touched on a few times recently, but I've been able to study it a little further. With this new info I'd like to get your information
Perf. Mods:
DP, CB, PowerFC
I was having an odd boost transtion. I would get boost pattern of 10-5-5>>creeping to 10 during a boost test. This was happening constantly with no deviation.
I swung by my mechanics place to have him take the car out for a spin and try to duplicate the problem. before we headed out, he adjusted the duty cycle (65% primary and 65% secondary) and we could not reproduce the odd transition.
later that night a friend of mine got his datalogit and we hooked it up to my PFC to test it out. Worked great. while we weren't recording, I was able to reproduce the same boost pattern, but not as freqently.
over the next week and a half I've been able to note the following:
1) exaust note change : when this transition problem occurs, there is a specific change in the exaust tone. The exaust gets louder, but less crisp.
2)4000 rpm flooring the gas: this transition problem most commonly occurs in 3rd or 4th when mashing the pedal after cruising.
3)I can correct the problem: If I feather the accelerator, or downshift and then accelerate I can usually get back to normal boost levels.
I'm hoping these descriptions are enough to have someone point me in the right direction.
Thanks
Bigred
Old Jul 24, 2002 | 07:12 PM
j9fd3s's Avatar
Community Builder
did it bolw that hose off the vacuum tank again?
mike
Old Jul 24, 2002 | 07:48 PM
BigRed's Avatar
nope.. that's not it mikey. I wish
Old Jul 24, 2002 | 07:57 PM
JONSKI's Avatar
5yr member, joined 2001
I'm deeply tempted to go non-seq to fix my 10-5-7 pattern.
Old Jul 24, 2002 | 08:06 PM
BigRed's Avatar
It happens alot less often now that my mech. changed the duty cycle. what/where does this control and is there a posibility of that getting stuck or breaking?
Queppa
Nov 18, 2024 03:47 AM
Skeese
65
Mar 28, 2017 03:30 PM
HDA
Nov 3, 2015 03:49 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
