Microtech lt8s injector question
Old Mar 6, 2012 | 09:51 AM
I fc3SLIDE's Avatar
FL lt8s injector question
i have a set of bosch blue top 1620cc injectors for my car they are low impedance if i buy a set of rc 1000's that are low impedence but work off a different ohm will i be alright thanks for the help... here are specs for both
bosch 1620's-Coil Resistance: 4.5 Ohms / Low Impedance
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 1600 cc/min = 152 lb/hr
Connector: Bosch EV1
Voltage: 8-15 Volts, Nominal 13.5 Volts
Amperage: Peak 4.0 Amps/ Hold 1.5 Amps
Pressure: Min. 36 PSI (2.5 bar), Max. 100 PSI (7 bar)
Intake with 12mm Viton O-rings on top
16mm Viton O-rings on bottom.
rc 1000's
Part Number: PL4-1000D (2 INJECTORS TOTAL)
Design: Peak and Hold (Low Impedance / Low Resistance)
Condition: 100% BRAND NEW
Flow Rate - CC's: 1000 CC's / MIN @ 43.5 PSI
Flow Rate - LB's: 95 LBS / HR @ 43.5 PSI
Resistance: 2.5 Ohms @ 68 F
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: Peak 4.0 Amps / Hold 1.5 Amps
Pressure: Min 30 PSIG / Max 100 PSIG
Old Mar 6, 2012 | 10:00 AM
rxspeed7's Avatar
F-IT
Yes they will be fine. You can run one low z inj per driver or 4 high z inj per driver.
Old Mar 7, 2012 | 01:11 PM
RotaryEvolution's Avatar
Sharp Claws
they just have to be matched pairs, ie i wouldn't run a 2.5ohm 1000cc injector with a 4ohm 1000cc injector for the primaries.
Skeese
65
Mar 28, 2017 03:30 PM
morataya
Microtech
Aug 16, 2015 09:39 AM
