water thermo valve broken :(
Old Feb 25, 2012 | 04:14 PM
FC3S_nataku's Avatar
mattg prob nt coming back
i just removed the water thermo valve from my s4 t2 throttle body and the inside piston is stuck (part number 13-980A-N304). i tested it as per the FSM and it just seems clogged is there any way to clean/rebuild this plug and if not, where can i buy a new one from other then mazdatrix? mazdatrix is pretty expensive at $60.59 each.
thanks
<a href="http://s639.photobucket.com/albums/uu117/luckysleven_fd3s/?action=view&amp;current=13-W870-N326.jpg" target="_blank"><img src="http://i639.photobucket.com/albums/uu117/luckysleven_fd3s/13-W870-N326.jpg" border="0" alt="Photobucket"></a>
Old Feb 26, 2012 | 07:50 AM
Landon303's Avatar
haha was w/ James yesterday as you were texting him.
Here's something that might work, if you have access to one? Ultrasonic cleaner. They can be bought at harbor freight for ~$40 I believe, which is cheaper than the part, IF it works. Good luck!
Also, I wonder how much different the part is compared to an NA TB part? Maybe they're interchangeable.
Old Feb 26, 2012 | 05:50 PM
sharingan 19's Avatar
Rotary Revolutionary
Don't fall for it landon, its a trap.
Old Feb 26, 2012 | 06:44 PM
its no trap you troll! lol
either way i have already fixed the valve.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Tem120
Sep 7, 2015 09:53 AM
