limp mode. who can tell me what codes?
Old Feb 15, 2012 | 04:58 PM
topspeed7's Avatar
rx7doingeleven
anyone know what specific codes cause the limp mode? my car is in limp mode but all the emissions have been removed even the wastegate solenoids so I don't know what to re install to get it out of limp mode. I know the wastegate solenoids cause it and the knock sensor too, but what other codes cause it?
Old Feb 15, 2012 | 05:16 PM
959595rotor's Avatar
old dog
Yes your limp code is caused by a bad oil pump, as well... when you replace it also repair or replace you computer as well .... there will be damage there as well...................
Old Feb 15, 2012 | 05:39 PM
oyvindjs's Avatar
on stock ecu, you have to bridge the connectors with a resistor to make the ecu think the solenoids are there. do you have the resistors in, and are they all working properly?
Old Feb 15, 2012 | 05:41 PM
j9fd3s's Avatar
Community Builder
in the FSM it actually lists the codes, and which ones are limp homes, so that's the simplest place to start....
Old Feb 15, 2012 | 06:47 PM
topspeed7's Avatar
rx7doingeleven
I do have some dummies solenoids but not on all, split air, vent etc.. mainly just on the wastegate and boost control. I have the FSM but I already got rid of the codes that supposedly cause limp mode, by the way omp is good no codes on that. no main component codes just solenoids. also the buzzer never stops off it's constantly on and it's not the coolant warning, that light goes off, or the oil light either. don't know if it's related to the limp mode issue
Old Feb 15, 2012 | 10:47 PM
topspeed7's Avatar
rx7doingeleven
just found the problem with the continous buzzer, turned out to be the airbag module.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Jmolina0163
19
Sep 25, 2015 06:06 PM
