polishing my intake.
Old Feb 6, 2012 | 06:38 PM
sideways-FC's Avatar
LOPEY IDLE
How do I polish my intake manifold so it looks like this?
Attached Thumbnails polishing my intake.-a4cadmtyzgca7y64kscamz8tytcaeb2kekcaurauf3cagt44npca0gxus1cacmucpmca2tkqbocaqvz8gwcaw9d327ca750r.jpg
Old Feb 7, 2012 | 10:55 AM
_KiD_'s Avatar
just look up a tutorial on polishing on google.You should be able to find something.
Old Feb 7, 2012 | 11:13 AM
lynchX's Avatar
Play nice rotary brothers
Always wanna try that out, I don't think theres much difference between polishing a wheel
Old Feb 7, 2012 | 11:28 AM
S8N's Avatar
S8N
Here's a great link http://www.rx7.org/Robinette/polish.htm hope this helps.
Old Feb 7, 2012 | 04:11 PM
hppwdn's Avatar
Sometimes I'll use a wire wheel to clean it up. Pretty quick way to get all the grime off and make way for some smoother polishing.
Old Feb 7, 2012 | 04:51 PM
LOPEY IDLE
I looked at that link looks like I need to get abunch of sanding and polishing disks and stuff.
Old Feb 7, 2012 | 05:05 PM
lynchX's Avatar
It's going to be a LOT of sanding the polishing part is usually where you starting to see your result
Old Feb 7, 2012 | 08:17 PM
LOPEY IDLE
yea I know. wheres the best place to get to sanding disks and stuff I need I already have the drill.
Old Feb 8, 2012 | 12:41 AM
mb3000's Avatar
Use 220 dry to get out all of the casting marks/imperfections.
400 wet to get out the scratches from the 220.
600 wet to get out the scratches from the 400. The piece should have a low luster at this point.
Go to Lowe's and get the polishing compound in the plastic tubes. I would recommend 1,2, &4. You need a different yellow (hard) wheel for each of the #1 & #2 compounds. Don't mix wheels. White (soft) wheel for the last compound.
Prepare to spend 40 hours or more on a perfect piece. Do it right and it will look similar to below.
Old Feb 8, 2012 | 04:26 AM
DoctorExcellent's Avatar
I'd love to clean up inside my engine bay, but that's almost TOO shiny.
Old Feb 10, 2012 | 03:59 PM
ramo's Avatar
always something to fix
40 hours! Now I'm demotivated to even try lol.
I wanna do my intake pipes and manifold and alternator and tstat housing. shouldn't a drill with the sand paper mounted make it shorter?
Old Feb 10, 2012 | 06:03 PM
LOPEY IDLE
Im just looking for a nice smooth serface with a dule polish so it always looks clean and dirt and grim wount get baked on to it so it wont take me 40 hours to get that.
Old Feb 10, 2012 | 10:09 PM
mb3000's Avatar
In that case just 1/2 *** the sanding up to 600 grit and use some Mothers Mag and Aluminum polish.
Old Feb 10, 2012 | 10:43 PM
gerald m's Avatar
Dragons' Breath
An alternative you might want to try is glass beads under lower air pressure it produces a satin type of finish looks nice and clean , we do a lot of motorcycle heads and so on that way .
The intake you could clear coat after I don't think there is enough heat to bother . just make sure you mask off all gasket surfaces and blow the hell out of it with air to make sure all the beads are out before installing . The thermo housing would be simple to do . The only real down side is the beads get in EVERYTHING and parts need to be cleaned thoroughly before installation . The alternator would need to be totally disassembled including replacing bearings .. IMO polishing looks great for a while but soon begins to tarnish again just from air exposure if nothing else .
It's a lot of work but the end result is super .
Old Feb 10, 2012 | 11:24 PM
ramo's Avatar
thanks for that, sounds like more work then i thought
what if i just did a certain amount of sanding, not to get a shine, but enough to put on a nice paint job, so that i dont have to worry about the shinyness anymore
since it does go away quickly, and you can just repaint if the paint gets old
is that all safe to assume?
Old Feb 10, 2012 | 11:54 PM
LOPEY IDLE
I thought about clear coating it when I was done so it dosnt tarnish.
