J-AUTO's new website for bushings and suspension upgrades!
Im a tall midget.
First off, just want to say thanks to everyone who has recommended my services to others, done business with me by either bringing in their cars for work or purchased parts from me. Your support keeps my small business growing little by little which in turn helps support the RX7club.com through my paid vendor membership. Thanks!
I just launched my website www.j-automotive.com but it's not 100% finished as I need to finish adding products to it. Please bear with me on this but I've got great products, that wont break the bank, coming very soon to keep our RX-7s kicking butt out on the street and track! The bulk of my customer's own FD's but I currently stock parts for FC's such adjustable toe links and camber bars. New products are coming and am planning on stocking suspension upgrades for older RX cars too
Feedback is greatly appreciated. For anyone looking to have their RX-7's serviced, please keep in mind that at this time, all work is done by appointment only.
Thanks,
Juan
Thanks,
Juan
Trending Topics
Im a tall midget.
Thanks for the kind words and compliments on the website. It was a steep learning curve and took me about a month's worth of part time coding and design work to have a functioning website
Thanks! Word of mouth referrals work wonders for me
Bring that grocery hauler over here for some upgrades and I'll get some good pictures of it on there
Don't worry, archaeologists just unearthed the technical suspension papers for RX-3's
I'll have some bushings for your cars in stock pretty soon!
Whats up!
I recently discovered your site, I see lots of fun toys I want to order!
I was curious about picking up both your toe links / camber bar for my FC, you mention not recommended for use with poly bushings on both these products. I've never seen that kind of warning before, what is your reason, and what should I use? Just keep with stock bushings?
(Trying to do a total suspension overhaul: poly bushings, AWR camber adjustments, toe adjustments... I want to get as fully customizable as I can.)
Im a tall midget.
Whats up!
Adjustable toe links also need the bushings to flex so the control arm can move freely. Spherical bearings for the rear control arms is ideal when using our toe links. You can get by with stock rubber bushings as well but spherical bearings is the way to go. Polyurethane bushings are stiffer than rubber and wont flex as much when you adjust toe settings. In other words, your control arms wont move as they should because the harder polyurethane bushings will cause binding issues. Poly bushings in the rear control arms are a great upgrade if you keep the stock toe links/lateral rods.
Cliff notes:
- Camber bar wont work with solid bushings. Rubber diff and subframe bushings is recommended.
- Adjustable toe links work best with spherical bearings on the rear control arms for smooth operation. OEM rubber bushings also work. Polyurethane bushings dont work and cause control arm binding issues.
Hope this helps
Thanks,
Juan
Thanks,
Juan
Im a tall midget.
Thanks!
I shortened my website url a little bit and it's now www.j-auto.net. The old url still works if you have it bookmarked but it just forwards you to the new url.
