Stub shaft removal
Old Jan 31, 2012 | 10:08 PM
twilight slide's Avatar
That looks broken
Stub shaft removal
So I've been trying to remove the passenger side stub axle on an s5 TII diff, to no avail. Tried a screw driver through the housing, tried a 2' breaker bar between the stub axle and the housing, all without results It slides in/out the normal 1/4", but after that no go. Am I missing something or did Jesus pound this in? Drivers pops out easy enough, the next step is heat but I feel that will do nothing as well. HALP?
Old Feb 1, 2012 | 10:09 AM
philiptompkins's Avatar
I think I got them out by hammering a chisel in the crack.
Old Feb 1, 2012 | 12:18 PM
RotaryEvolution's Avatar
Sharp Claws
prybar between the diff case and the axle.
the axle is held in by a spring c-clip only but over time it bites in pretty hard and can take a bit of leverage to pop them out.
Old Feb 1, 2012 | 12:49 PM
87 t-66's Avatar
not a drifter
+1 on the prybar
Old Feb 1, 2012 | 11:44 PM
That looks broken
I used a punch/5lb min sledge through the diff as my 2' breaker/pry bar was doing nothing. The culprit was a damaged c-clip that was bent outwards slightly, managed to take a nice chunk out of the stub shaft.
Old Feb 2, 2012 | 09:37 AM
Sharp Claws
sometimes you have to tap the stub inward toward the diff and walk it back and forth if it is being stubborn.
Old Feb 2, 2012 | 07:09 PM
That looks broken
I gave this thing hell before using the punch. In/out, 2 pry bars at the same time, ridiculous. Does anyone know, if some up/down/left/right play normal for the stub shafts to have? It's minimal, maybe .01 or so at the flange. This is on a Kaaz BTW.
Old Feb 2, 2012 | 09:10 PM
john ward's Avatar
oi oi oi
Sometimes it helps to use a prybar on one side with light pressure then one on the other side with a snapping force. Makes the force more strait out and less to the side.
Old Feb 4, 2012 | 11:52 PM
TII_Arekusu's Avatar
Just make sure you dont have that pry bar anywhere near that aluminum rear cover on that thing.,. Mine came out with a pry bar and hammer.. good luck.
Old Dec 20, 2015 | 09:36 PM
fbse7en's Avatar
Old Dec 21, 2015 | 01:13 AM
misterstyx69's Avatar
Retired Moderator, RIP
Sandals not included..
No toes were injured during the filming of this video!
Enzo1944
Sep 6, 2015 08:57 AM
