Disk brake conversion
Old Jan 31, 2012 | 07:43 AM
ls63's Avatar
I have a 1983 rx7 that im converting to limited slip I noticed that im gonna have to run new brake line to the calipers, when I took out the old rear I disconnected the brake line in the rear where the line connects to the rear and then distributes to the drumbs..is there a way I can use that for the limited slip or do I have to run lines from the master cylander
Old Feb 1, 2012 | 02:15 PM
rx7dd97's Avatar
Convertible Guy
You can use the existing brake line.
Old Feb 1, 2012 | 04:51 PM
Kentetsu's Avatar
The problem is that the thread pitch changed between model years. Contact Sam at www.re-speed.com They carry adapters for just this purpose.
chiefmg
Sep 10, 2015 07:46 AM
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
