Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
2jz question
Old Jan 26, 2012 | 05:20 PM
JTO's Avatar
JTO
2jz question
ok so i traded my s13 hatch for a 2jz fc now im just trying to hook up the power steering but iv had a few places tell me diffrent things one person says block off the small hole on the rack with a bolt and crush washer someone also said run a (T) in the hoses if some ones got some kind of diagram on what they did it would really help because im kinda getting spun in circles on how to do it thanks
Old Jan 27, 2012 | 07:21 PM
flyboy333's Avatar
Just a hint of crazy.
I hate to answer without answering, but you could probably figure it out if you just know which port is the high pressure side off the pump and which is the low pressure side back to the reservoir, unless there's some major weirdness high side line to high side port and return port to return line should be the most of it...
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
