the housings for the diff between the turbo 2 and n/a
Old Jan 26, 2012 | 02:09 AM
FTW RX7's Avatar
OR the housings for the diff between the turbo 2 and n/a
is the housings between the rear end diff houseings different between the second gen turbo and n/a rear end housings. i know they are different diff them self but would like to know if the housings are
any knowledge would help thanks
Old Jan 27, 2012 | 01:13 PM
tharltjr's Avatar
thomas hen
also the turbo housing it a lot sturdier the stock diff is only a peg leg to when you switch it over to the turbo one it will be either a viscous or a torsen and i would suggest the torsen cause the viscous is a clutch type and they tend to burn out really fast depending on the type of driving you plan of doing I.E. track or drift
Old Jan 28, 2012 | 06:41 PM
RotaryRocket88's Avatar
Top Down, Boost Up
^ No, FC limited slip rear ends are either clutch type (S4) or viscous (S5). Viscous is not the same as a clutch type rear end. Only an FD rear end is going to be torsen.
The TII rear end uses an 8" ring gear, while all NA rear ends (open and LSD) are 7". The halfshafts are larger, most everything else is larger, and it's built a good amount stronger. But an NA rear end can still handle a good amount of power, unless you abuse it regularly. I've used an S4 NA LSD in my turbo swapped car for the last 3 years without issue, and others have used them with larger turbos.
Old Jan 29, 2012 | 07:59 PM
FTW RX7's Avatar
guess i mean can i use turbo 2 diff mounts in a n/a diff mounts
i run a welded
cristoDathird
28
May 30, 2019 08:47 PM
