different style TPS and other questions.
Old Jan 22, 2012 | 09:23 PM
hondaguy1992's Avatar
Wheres my VTEC?
DE different style TPS and other questions.
Is it possible to run a different style TPS? like say a GM style on a GM throttle body? My plans are to run a GM 80mm throttle body by a custom adapter plate. the one i have has a 3 wire TPS like the one in my s4. to my knowledge, one wire is a power, one is a ground, and one is a signal? so id just have to match the wires from the GM style TPS to the wires in my s4 and i should be golden?
Also, im in dire need of a new engine harness, i tried rebuilding it, but i got about half way and realized i dont have the time/patience for that much wiring right now and the old harness was toast. I have a 88 shell, with what i believe is an s5 TII engine and trans, and i would also need a BAC valve for a s5, if you have one hit me up....
thats about it, i need to get this car on the road asap...
thanks again
Donald Hampton
Sep 20, 2015 09:09 PM
ZacMan
Sep 19, 2015 09:20 PM
