new stock sized inejctors?
Old Jan 19, 2012 | 01:24 AM
SpAm@FC's Avatar
Hi guys...
wanted to know if there is a solution for throwing the old stock injectors into the bin, and change them with some new, shiney, maybe aftermarket injectors? (except mazda OEM or get the stock ones cleaned and tested)
stock ecu, stock harness, stock rails...
thanks in advance
Patrick
Old Jan 19, 2012 | 04:53 AM
dgeesaman's Avatar
Since side-feed injectors aren't a popular design, OEM injectors are the way to go for stock fuel levels. I do feel it's worthwhile to get them ultrasonically cleaned and tested every couple of years. Make *sure* the service you can has the ability to mount a side-feed injector and robustly test their spray/flow. Cleaning without testing can lead to stuck injectors.
Old Jan 19, 2012 | 03:04 PM
j9fd3s's Avatar
Community Builder
you can have them cleaned/tested but i have seen more than a few injectors leaking from the electrical connector, and i'm not sure that's repairable...
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
