single turbo wiring help
Old Jan 8, 2012 | 09:23 AM
Grant M's Avatar
RX 4BPT
i really need some help on the Identification of some of the cables im not 100% for my chopped down engine harness. this is going in my RX4 BPT. i have plenty of pictures and wire colours to help.
first off is this the fuel temp plug?
(ss= silver stripe)
Green plug;
wire colours are black brown ss
green white ss
Do i need it and where will i plug it in with me using this in my RX4?
AIT ( air inlet temp?)
black plug, yellow inside;
Green ss
black brown ss
Obviously i need this, have i to replace the plug along with getting a new fast reacting IAT sensor, and where is the best place to put the new sensor? as near too the throttle body as possible?
IAC, What is this and what does it do?
white plug;
blue green ss
black white ( i assume this is a ground?)
thermostat water temp, i have 2 plugs
Green plug;
black brown ss
brown yellow ss
Black plug;
Blue yellow
black white (Ground?)
the green one fits onto the socket on the water pump housing rear ide but where does the black one go?
water thermo switch.
does this wire, red black go with this black plug? does this plug tell the ecu the temp. and then this turns the fans on? do i need it or can use something aftermarket to control the fast through a seperate thermoswitch and manual switch?
what does this black plug do?
blue ss wire
black white wire
i think this is the AWS, however i dont know what it does and what it stands for.
black wire with braiding
TPS
2 X brown white ss cables ( i think they were crimped together, i assume that this colour wire is voltage/power as it is splice throughout the harness for various things)
black green ss
green red ss
black brown ss
what does each of these wires do? i assume one is power/voltage, a ground and a return signal to the ecu to tell it what the TPS is doing.
the plug for the TPS on my EFI hardware throttle body has 3 cables in it,
Red- voltage in?
Green- return signal to ECU
Black- Ground??
what is this black plug for?;
yellow white ss
GEarbox plugs;
what does the yellow inside black plug 4 pin do?
red ss
yellow ss
blue ss
white ss
Grey plug 2 pin, orange inside
brown ss
green ss
what does it do?
Brown plug, orange inside 2 pin;
orange ss
green ss
Black plug yellow inside 2 pin
green yellow ss
yellow red ss
Old Jan 8, 2012 | 09:40 AM
do a search on wire schematic or get the FSM off here somewhere its a free PDF
try this link
https://www.rx7club.com/showthread.p...ghlight=fd+fsm
Old Jan 8, 2012 | 10:34 AM
Gringo Grande's Avatar
1.5 Goodfella's Tall
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/how-single-turbo-harness-879345/
Old Jan 8, 2012 | 12:01 PM
Grant M's Avatar
RX 4BPT
Originally Posted by Gringo Grande
thanks, thats what i started off using to strip mine down, but i cant identify the few cables i have left on the harness from the pictures in that thread, i cant even tell what colour cables they are once i zoom in on the picture. i just want to make sure i dont strip out one thing i need as i got them mixed up.
sherff
Feb 24, 2019 12:09 PM
