need help 13b swap
Old Dec 31, 2011 | 07:53 PM
Denser's Avatar
need help 13b swap
i bought the engine of the fd the twin turbo one and just need some info would the re speed cross member fit this along with the racing beat holly kit and should i change the fuel lines? any advice greatly appreciated
Old Jan 1, 2012 | 12:10 AM
nff's Avatar
nff
your putting the 13brew in a fb but your not going to run FI? is the holly boost preped?
Old Jan 1, 2012 | 01:45 AM
Sgt.Stinkfist's Avatar
premix, for f's sake
As far as I knew the REW motor doesn't swap into 1st Gen chassis using the "traditional" front cover method, so your goin to have to come up with a different mounting style. I also wasn't aware that there are Holly carb/manifold kits the bolt to the REW
Old Jan 1, 2012 | 03:44 AM
Denser's Avatar
reason why i ask new to the whole rotary scene i wasent sure if everything bolted up or what i needed exactly to make this swap possible
Old Jan 1, 2012 | 12:45 PM
Jeff20B's Avatar
Lapping = Fapping
A 12A front cover does fit an REW engine. Use a GSL-SE pan. Drill+tap a couple of holes in the rear plate for 6mm x 1.00.
The usual modified "13B into 12A chassis" front mount bar is required.
Tranny/starter is dependant on which flywheel you use. Stock FD requires T2 trans swap. To keep your current trans, get an S5 NA flywheel.
There's a bit more to it, but this gets you started.
Old Jan 1, 2012 | 06:25 PM
Denser's Avatar
thanks man i really appreciate this
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
mulcryant
Sep 9, 2015 05:24 PM
