AEM EMS Area is for discussing the AEM Engine Management System!
AEM AEM Boost Comp Map.
Old Dec 23, 2011 | 04:23 PM
superjet3's Avatar
AEM Boost Comp Map.
I got my car up and running with the AEM using a boost comp map. I am still learning. I am having much better results with this over the Alpha N map. It is running well at idl but just a little rich. The motor is new and I have heavily premixed gas in the tank... Here is a quick video of it. I also attached the map to see if anyone has some input.
ID725 and ID2000 injectors
GT3583r
Twin Power
Pineapple template street port
Supra Pump
http://youtu.be/nas--jf2kQQ
Old Dec 29, 2011 | 08:38 AM
EB Turbo's Avatar
What were your issues with the alpha n map?
Old Dec 30, 2011 | 11:13 AM
superjet3's Avatar
The car did not want to idle well. It was very jumpy.
Old Dec 30, 2011 | 10:37 PM
D Walker's Avatar
I can maybe help you, my e85 car runs a similar setup. shoot me a PM with your contact info.
Old Dec 31, 2011 | 01:50 AM
EB Turbo's Avatar
There is quite a bit that goes into idle quality just on the idle control side. Did you try setting the idle Target table and verify all of the other idle control tables/inputs. You still need to make sure you have steady idle AFRs.
t-von
Sep 10, 2015 01:56 PM
