Haltech from staged to batch inj
Old Dec 13, 2011 | 01:44 PM
RX200013B's Avatar
right now i am set-up w/ staged inj. wired bank 1-2 pri, bank 3-4 sec. will i need to rewire for batched inj? to make it fire channel 1 & 3 together and 2 & 4 together? or am i confusing myself?
set-up. 13b n/a hbp e6k.
also looking for a TPS base map?
Old Aug 30, 2012 | 02:00 PM
Brandon Robinson's Avatar
Mr. Fix-it
If you are not running a very large port you need to stick with Map based timing. TPS based timing is for n/a cars that have trouble creating vacuum where a Map sensor is useless, Map based timing is the most accurate where tps timing will not be accurate on tuning. and yes you are confusing yourself... You want to stick with staged injection because you dont really need those secondary injectors untill the 5th and 6th ports open.
RX200013B
Haltech Forum
Oct 12, 2015 09:45 PM
LongDuck
Oct 7, 2015 08:12 PM
lnlreaper
Sep 27, 2015 09:59 AM
