91' Vert is falling on it's face :/
Old Dec 11, 2011 | 12:55 PM
rx7freek's Avatar
rx7freek
Hey guys, I have a 1991 s5 vert. She will start fine. Then will Idle erratically once warmed up. the rpms will climb from 840 to around 1000 in about a second or two. then fall back down. This continuously repeats. Once I get driving and I put my foot down, the check engine light comes on. From this point if I apply any more than about half throttle, the engine will fall on it's face. rps drastically drop and the engine sputters a terrible amount..
What could possibly be the problem??
thanks in advance
-RX7FREEK-
Old Dec 11, 2011 | 02:07 PM
AGreen's Avatar
Trunk Ornament
Wrong section. This should be in the 2nd generation specific, not build threads.
Anyways, the throttle position sensor is probably out of adjustment.
http://www.rotaryheads.com/PDF/2nd_gen/
Section 4a of the 89-91 manual will tell you how to adjust it. You can also make a little checker with some LEDs, and there are many many threads about it here. Use the advanced search feature and do a title only search for TPS checker.
Old Dec 25, 2011 | 04:42 PM
kagoostin's Avatar
Yeah your TPS is probably bad, i had the same issue and replacing it, took the check light off. See what code the check light throws at you.
Old Dec 26, 2011 | 09:43 PM
rx7freek's Avatar
rx7freek
Thanks. as soon as I can afford a new one I will try it out and update you all.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
MidnightOwl
Sep 25, 2015 10:24 PM
