Godspeed Project MAZDA RX7 86-91 TYPE-RS COILOVER SUSPENSION
There are only a few sets available from our recent shipment so act fast!
PM ME FOR BEST PRICING SHIPPED TO YOUR DOOR!
Local pick is available as well. Must PM ME before picking up!
86-91 MAZDA RX7 (FC) TYPE-RS 16 WAYS ADJUSTABLE COILOVER DAMPER KIT ( 2 FRONT STRUT, 2 REAR STRUT)
GODSPEED TYPE-RS Coil-Over Dampers is the perfect enhancement to your track or street car. Featuring 16 Levels of damper force adjustment, full-height adjustment.
The damper can easily adjusted by turning the **** at the top of the damper. Turning the **** can simply change your daily driving or track day needs. The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can easily raise your car to oem height or lower your car for track performance.
The quality and durability of the GODSPEED Racing Damper kits are made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. we stand by our product with 1 YEAR warranty. (from date purchase. Must be installed by professional tuning shop)
Features:
- Spring Rates: 8 kg Front and 6kg Rear
- 16 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
- All Hardware is Included
Features:
- Aluminum Brackets
Trending Topics
Please check out our FAN PAGE and click "LIKE" : http://www.facebook.com/GodspeedProject
