A question about compression (pettit motor)
Old Jul 18, 2002 | 08:24 PM
wolf50000's Avatar
Hey everybody,
I have a question for all of you. I am thinking about buying an RX7 with a Pettit Racing engine in it. Today, I took it into get a compression check on the rotors. Both rotors were at 6 kg/cm2 or 85 lb/in2.
Is this normal for a rebuilt Pettit Engine? It was explained to me that maybe the reason that the compression was lowered by Pettit to prevent "Pinging" as he called it.
What's your opinion?
Thank you!
Ryan C
P.S. It's the fastest car I have ever been in!
Old Jul 18, 2002 | 08:48 PM
R Xplicit's Avatar
i have a pettit engine, it is ported and was also dowell pinned. i was told nothing of lower compression. and do not know the exact numbers that they should be at. call cameron worth at pettit. their number is....561-844-2258.....
hope this helps...
Old Jul 18, 2002 | 08:57 PM
Nathan Kwok's Avatar
Thats BS. Call Pettit and repeat what he said and see what they have to say. The only way to lower the compression would be to use rotors from the 86-88 TII, which I HIGHLY doubt they did. The compression numbers are borderline too low although if they are perfectly even then thats not so bad. Depending on the price it could still be a good buy but I don't like the idea of the seller lying to you. The car can still give many more miles but I'd set aside money for a rebuild.
Old Jul 19, 2002 | 05:03 AM
duboisr's Avatar
you can lower compression by milling the rotor faces and rebalanceing ,lower compression-higher boost= more power.
Old Jul 19, 2002 | 11:47 AM
bee's Avatar
bee
the numbers are fine.. Its almost impossible for both rotors to be losing compression at the exact same rate. Im sure it could happen but ive been around alot of dying rx7 and have never seen it..
cristoDathird
28
May 30, 2019 08:47 PM
elfking
Aug 19, 2015 09:48 PM
sYnth.
Aug 19, 2015 06:27 PM
