13b t2 S4 -> 13b NA S4 conversion
Old Oct 8, 2011 | 02:30 PM
Pettersen's Avatar
So found a cheap S4 NA engine to use while i finish building my turbo engine and get the papers to get it street legal.
Thought it was a fairly straight forward job, and that i would just need to change the ECU and pressure sensor, but it looks like i need to change my wiring loom :/
The NA engine came from a 1986 NA, it came without the distributor cap or coil.
What do i need to do? change the wiring loom? or is there another way?
Old Oct 8, 2011 | 03:30 PM
w.sen's Avatar
In a Bucket
ecu harness, pressure sensor, maf needs to be changed and the wiring to to guages might be different since the t2 has a lil boost gauge.
Old Oct 9, 2011 | 05:02 AM
Pettersen's Avatar
Can i change the distributor for a CAS in order to use my T2 coils?
Old Oct 9, 2011 | 11:32 AM
Pettersen's Avatar
So i have read a bit, and since my car already has a wiring loom for the "standard" S4 engines, i should just need CAS, NA S4 ECU and maby a NA S4 MAF if it's different from the T2.
Wich "Nxx" numbers are on the parts i need?
Old Oct 9, 2011 | 12:11 PM
misterstyx69's Avatar
Retired Moderator, RIP
S4 N/A : N numbers are N326 or 327.
Coochas
44
Nov 5, 2019 11:08 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
