Where did all the bushings go?
Old Jul 17, 2002 | 05:02 PM
Ridge Tech's Avatar
I'm trying to get my hands on a set of Engery Suspenison bushings. Nopi doesn't have them in stock, 4 to 6 weeks backorder, Victoria British says they dont have a supplier for them. Where can I get a set of these? School starts back soon and I want to get them in before then.
Old Jul 17, 2002 | 05:09 PM
akageals's Avatar
mazdamotorsports.com
These are considered "competition parts" so you should be able to purchase them. I just got a set delivered today from them .
Todd
PS. Although they come from mcomp, they are the energy suspension bushings. You can also try suspension.com but I think they are more expensive there.
Old Jul 17, 2002 | 06:10 PM
Ridge Tech's Avatar
what is the part # at mcomp.
Old Jul 17, 2002 | 07:57 PM
akageals's Avatar
I don't know the part #. I just called and asked for P.U. Bushings for the swaybar, end links, and control arm. On their website just search for bushing and you should be able to find them.
Todd
Old Jul 17, 2002 | 07:59 PM
akageals's Avatar
0000-02-9411 C BEARING KIT, TAILSHAFT 1 RX-2, RX-3, RX-7 ALL 1974-91 $27.70
Notes: Transmission tailshaft bushings often seize due to the high rpm seen in competition. The only way to avoid these failures is to install a needle bearing in place of the bushing. fitment of the needle bearing requires machining out the inside diameter of the tailshaft housing. The tailshaft bearing kit includes needle bearing, snap ring and information regarding the tailshaft machining. Use of a hardened competition driveshaft yoke, 4352-25-130A, is required with this modification.
0000-04-7401-KT C BUSHING KIT, FRONT CONTROL ARM - DELRIN 1 RX-7 ALL 1986-91 $137.80
Notes: Delrin bushings to replace stock front control arm bushings. Both sides.
0000-04-7401 C BUSHING KIT, FRONT CONTROL ARM - URETHANE 1 RX-7 ALL 1986-91 $39.90
Notes: Urethane bushings to replace stock front control arm bushings. Both sides.
0000-04-7406 C BUSHING KIT, FRONT SWAY BAR 1 RX-7 ALL 1986-91 $14.30
Notes: URETHANE. Front sway bar bushings for stock size bar.
0000-04-7402-KT C BUSHING KIT, REAR CONTROL ARM - DELRIN 1 RX-7 ALL 1986-91 $138.20
Notes: Delrin rear control arm bushings. Includes front outer, rear upper at triaxial hub, and toe steer eliminator bushings. Both sides.
0000-04-7402 C BUSHING KIT, REAR CONTROL ARM - URETHANE 1 RX-7 ALL 1986-91 $10.90
Notes: Urethane front outer, rear control arm bushings. Both sides
0000-04-7403-KT C BUSHING KIT, REAR SUB-FRAME - DELRIN 1 RX-7 ALL 1986-91 $85.50
Notes: Delrin bushings replace the stock rubber in the rear subframe.
0000-04-7407 C BUSHING KIT, REAR SWAY BAR - URETHANE 1 RX-7 ALL 1986-91 $10.75
Notes: URETHANE. Rear sway bar bushings for stock size bar.
0000-04-7405 C BUSHING KIT, SWAY BAR END LINK - URETHANE 2 RX-7 ALL 1986-88 $14.30
Notes: Urethane sway bar end link bushings. For front or rear bars. One kit per sway bar.
0000-04-7404-KT C BUSHING KIT,TOE-STEER ELIMINATOR 1 RX-7 ALL 1986-91 $46.40
Notes: Delrin bushings replace stock bushings, eliminating rear suspension's toe-steer characteristics. Both sides.
0000-04-7326-ST C SWAY BAR , FRONT - SUSPENSION TECHNIQUES 1 RX-7 ALL 1986-88 $145.60
Notes: Front bar only, with bushings and mounting hardware. 28mm #50165
0000-04-7336-ST C SWAY BAR, REAR - SUSPENSION TECHNIQUES 1 RX-7 ALL 1986-88 $138.20
Notes: Rear bar only, with bushings and mounting hardware. 19mm.
akageals's Avatar
That is directly from their web site
Old Jul 17, 2002 | 08:33 PM
deadRX7Conv's Avatar
Opinions are like........
http://www.suspension.com/mazda.htm
What I want to know is where do you get those motor/trans/diff mounts that are better than stock ones.
Old Jul 17, 2002 | 08:58 PM
Ridge Tech's Avatar
good god, thats a lot of bushings
Old Jul 17, 2002 | 11:21 PM
ALTurbo2's Avatar
I just recieved my stronger front diff mount yesterday. This is the catalog, but I couldn't find the front diff mounts after numerous searches. However, the guy I spoke with was really helpful. Give them a call and they'll tell you what you need.
pfsantos
Sep 30, 2015 01:29 PM
