Microtech explosion inside engine
Old Sep 26, 2011 | 09:09 PM
cartechturbo's Avatar
NJ explosion inside engine
here is wat happen i rebuild me engine put it in the car first i had a lower injector stuck leaking gas in the engine ,then on day i went to start the engine car start good run for 10 minutes shut her off after an hour went to start her again i just put the igition on loud boom came from the engine bend the butterfly on the trottle body to a L shape i took the trottle body out and fix the butterfly ,now i replace the stuck injector car start good idle nice thinking the explosion problem went away cause i fix the stuck injector well yesterday i start the car idle good rev good after 30 minutes i shut her off after another 30 minutes i went to start he i just put the igition then a loud boom came from the engine again bend the butterfly again
anyone know why i am having these explosion thanks
cosmo 13b 2 bribge
microtech ltx8
Old Sep 27, 2011 | 08:30 PM
Sammy Built's Avatar
501 WHP Club
I've had that happen before like a backfire as soon as I turn the ignition on never bent butterfly's though. I
thinks it's fuel in the chamber though maybe it gets ignited and the backfire pops.
Old Oct 3, 2011 | 12:33 PM
RotaryEvolution's Avatar
Sharp Claws
obviously you are still getting fuel leaking into the engine while it is parked..
The Shaolin
Sep 14, 2015 07:50 PM
