Sway bar links
Old Jul 16, 2002 | 03:40 PM
ddr10's Avatar
Front Swaybar links
I need to replace my front swaybar links - dealer is about $60 per side - my question is:
Do aftermarket front swaybars come w/ these links? Should I opt for upgrading the stock swaybar?
Who makes aftermarket bars you's recommend?
Thanks!
Old Jul 16, 2002 | 07:06 PM
GoRacer's Avatar
Speed Mach Go Go Go
End Links
You can get the MazdaComp sway bar end links from Mazdatrix. Sway bars do not come with them, but both Eibach and HKS make a sway bar set.
You should at least get the beefy Mazdacomp end links. My stock ones crushed like a soda can.
Old Jul 16, 2002 | 07:34 PM
Trexthe3rd's Avatar
Suspension Technic also makes a set. The end links from mazdatrix is 75.00 for the pair.
Old Jul 16, 2002 | 08:16 PM
rx7tt95's Avatar
Photo Diety
I have the Mazdatrix end links with the Suspension Techniques sway bars. The rear has two adjustments. They're HEAVY. Eibach no longer makes swaybars for the FD. RE Amemiya, mazdaspeed and a few other Japanese tuners make them. The choices in the U.S. are Tripoint, M2 (same bar?) and Racing Beat.
Michel
Old Jul 16, 2002 | 08:37 PM
MilesBFree's Avatar
Walking bowl of punch
The Tri-Point bar is the best choice, IMHO. It ain't the cheapest, however.
For do-it-yourself end links, which are almost exactly what Tri-Point ships with their bar, See my site, and go to: Upgrades --> Suspension Anti-Sway Bars --> End Links.
Cheers,
Steve
http://www.ScuderiaCiriani.com/rx7
