Power FC Is my PFC dead?
Old Aug 23, 2011 | 02:03 PM
timhill78's Avatar
Is my PFC dead?
My car died at a local autocross last weekend and i can't figure out what's wrong. It will turn over but die immediately. I've checked the sensor read out on the PFC and they are way out of whack.
PIM 0.03
VTA1 0.01
VTA2 0.01
VMOP 0.00
I installed the stock ECU and it fires right up and idle ok. I've removed the airpump so it's not perfect but ok.
I tried replacing the TPS in hopes that it would make some difference but it doesn't. I've also tried disconnecting the map and tps to see if the reading change and they do read that they are disconnected.
Any ideas?
Old Aug 23, 2011 | 03:46 PM
arghx's Avatar
rotorhead
Are you sure you didn't have a loose ECU plug or something? Check the harness. If you send your PFC to Apex'i you will be waiting on it for months.
Old Aug 23, 2011 | 03:52 PM
vosko's Avatar
Just Call Me Terminator!
pop the cover on your pfc check for any burnt traces. that usually only happens from a bad wiring harness or loose connection like arghx said
Old Aug 23, 2011 | 04:39 PM
timhill78's Avatar
Popped off both covers on the PFC but I don't see anything. The wiring harness on my car is only a few years old. So I don't think that would be the problem.
Old Aug 23, 2011 | 05:15 PM
arghx's Avatar
rotorhead
Check fuses.
Old Aug 23, 2011 | 06:02 PM
timhill78's Avatar
The fuses all look good.
When I step on the throttle the readings change slightly.
PIM 0.04
VTA1 0.03
VTA2 0.03
VMOP 0.00
Old Aug 23, 2011 | 06:33 PM
arghx's Avatar
rotorhead
Sounds like an open circuit on a reference voltage wire.
Old Aug 23, 2011 | 06:41 PM
timhill78's Avatar
Why would it run on the stock ECU then. That's the part that really has me puzzled.
Old Aug 23, 2011 | 08:58 PM
ttmott's Avatar
Check Pin 4D on the PFC board. It may have broken or had a bad solder joint. Or the wire to the connector for Pin 4D.
Old Aug 23, 2011 | 10:01 PM
timhill78's Avatar
I double checked the PFC board. It looks good. I also checked the connector. It also looks good. Still not working.
Old Aug 24, 2011 | 02:07 PM
timhill78's Avatar
I think I may have tracked it down to 3I pin. I only get .03 signal out of it. Does it make sense that it's the problem?
Old Aug 24, 2011 | 10:13 PM
Turbo8's Avatar
REPU Garage
I had the same issue with a PFC I had once. I had an electrical engineering friend look at and he said all those sensors share a common ground within the PFC and when it goes bad, it will not read voltage from those sensors (obviously).
Old Aug 24, 2011 | 10:23 PM
timhill78's Avatar
Did a new PFC fix the problem? Did you have any issues since the new pfc?
Old Aug 25, 2011 | 08:22 PM
Turbo8's Avatar
REPU Garage
Yes, I replaced the PFC with a brand-new unit and no problems, been running fine ever sense.
General rule of thumb is; if the car won't start on the PFC, but will run fine on the stock ECU, then you have a bad PFC. This, of course, isn't taking into consideration a tune so horrid it would prevent your car from starting, but I highly doubt this is your case.
I will call him and see if he remembers how to fix it, it said it wouldn't be too bad if I recall.
Old Aug 25, 2011 | 08:31 PM
Turbo8's Avatar
REPU Garage
Just called my engineer friend...
He said most likely it's a bad 5v regulator internal to the PFC. Should have part #7805 (generic part #) or circuit IC18 on the PFC main board, usually a 3-pronge chip on the board (with a tab on the back to bolt to the board/chassis).
If you can de-solder the chip and remove it, solder it back in, it should only cost you $2 for the part.
Old Aug 25, 2011 | 10:08 PM
timhill78's Avatar
Thanks for the info. I think I might get another PFC and send mine in to Apexi to get fixed then sell one of them. I can't be without my car for 3 months and i don't trust my soldering enough to do it myself.
Old Sep 8, 2011 | 07:38 PM
timhill78's Avatar
Progress update: Got a new (used) PFC. Installed it. Car ran great. Today coming home from work it dies again. Same thing. Same from the sensors. I put in the stock one again and it started right up.
Does this mean I have a short? I take it I need to track down the short and get another PFC? How do you go about tracking down a short?
Old Sep 8, 2011 | 10:29 PM
trainwreck517's Avatar
Rx-hippie
Have you checked your Alternator output?
With the stock ECU, fire up the car and measure the output of the alternator to ground while revving to 3krpms. The output voltage should be ~12.6-13.8V. If you are seeing anything higher than 14V then the alternator most likely killed the PFC. I have seen a bad alternator feed up to 18V which killed the battery and knocked out a PFC.
Worth a shot taking a look. I am not to sure it would be a short, considering it runs with the stock ECU.
Have you already sent the first PFC to apexi? They may be able to help you determine the root cause of failure.
Good luck
Old Sep 8, 2011 | 10:36 PM
timhill78's Avatar
Good luck
I'll check that tomorrow.
I've haven't sent in my PFC yet. It's good I waited. Now I can save on shipping by sending two at once.
Old Sep 9, 2011 | 02:41 PM
timhill78's Avatar
I just checked the alternator. It seems to be good. Any other ideas of things to check? I appreciate any ideas.
Old Sep 28, 2011 | 08:30 PM
JDK's Avatar
JDK
Check the wiring harness under the front drivers side wheel well, I burnt though a few wires in this location and it took out my PFC
Old Sep 30, 2011 | 12:01 AM
timhill78's Avatar
I haven't updated in a while. This was the problem. Now I just need to get another PFC.
Old Oct 2, 2011 | 02:33 PM
JDK's Avatar
JDK
I have mine out for repair at a local shop that rechips ECU's, I'll let you know if this works out, may save you a lot of time and money.
Old Oct 2, 2011 | 11:15 PM
timhill78's Avatar
I broke down and sent my two fried ones to Apexi. They said it typically doesn't cost more than $150 ea to get repaired.
Old Oct 6, 2011 | 05:48 PM
Turbo8's Avatar
REPU Garage
When I contacted Apexi about repairing a malfunctioning PFC I was told if the repairs exceeded $300 I would simply be given a new one.
