2gen Fuse block install question
Old Aug 10, 2011 | 06:52 PM
jonjonwells's Avatar
I am having trouble getting the connections on the bottom of the unit. A standard spade is just not fitting.
What did you use to make the connections, and where did you get them?
Old Aug 10, 2011 | 10:06 PM
85TIIDEVIL's Avatar
ALLROTOR
Took a standard spade and stretched it open just a hair with two pairs of needle nose pliers. It fits on there so tight they've worked flawless for 5+ years now.
Old Aug 11, 2011 | 01:35 AM
KansasCityREPU's Avatar
Out In the Barn
NAPA sells the correct size. I believe they are yellow in color.
Old Aug 11, 2011 | 01:58 AM
blown7's Avatar
Double Ds for me to share
I got my 2nd gen fuse block with the factory connectors so all i had to do was cut my wires and connect to the second gen wires.
Old Aug 11, 2011 | 08:39 AM
82transam's Avatar
Never Follow
Good to know, I couldn't find the correct size when I installed one years ago, spread a normal spade a bit and it worked fine. Later got the plugs off an FC harness to clean it up a bit...
Old Aug 11, 2011 | 12:05 PM
85TIIDEVIL's Avatar
ALLROTOR
Yup, a little spread on the blue ones worked real good, nice and extra tight. Beat a trip to the parts store for the right size.
Parts store / radio shack sell them things like 10 for $5... Steep, but if your in a bind I guess u have to pay. I pick up a bag of 100 for $5.00 at the swap meet. Dropped like $50-100 this year on all kinds of connectors and now have enough to last for years.
Old Aug 11, 2011 | 05:45 PM
Out In the Barn
What I did was take a hammer to remove the brown block that holds the old wires. Then just remove the wires from the copper strip and crimmped on new connectors. I then used a short length of battery cable to attach a ground from the new 2nd block to ground on the shock tower and another short piece to connect to the hot side of the battery.
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
