weber tuning help on 12a stock port!!
Old Aug 4, 2011 | 08:24 AM
henry zayas's Avatar
85gr3yFB
FL weber tuning help on 12a stock port!!
just got my weber dcoe 45 installed on my 85 12a and was not impressed. i know that it still needs to be tuned but at least expected it to perform better that the nikki :/. i am new to webers and have been trying to see how i should tune mine. right now i know its running too rich bc its wasnt a **** load of gas. i wasted about 1/8 tank and only went 25 miles. and if im crusing under 2000rpm its somewhat smooth and crusing anywhere above 2k causes it to sputter, alot. and if im cuising at a higher rpm like 4k or 5k it sputters so muc it sounds like its on a limiter. and if im flooring it lower to midrange power is OK but high rpm is almost none. the carb has f-11 e tubes on it, thats about all i know so far. someone help
Old Aug 4, 2011 | 08:57 AM
85gr3yFB
also my idle jets (i believe thats wat they r) are 60-f10
Old Aug 4, 2011 | 09:01 AM
rx71king's Avatar
the diabolical one
36 to 37mm chokes
180 main
150 air corrector
70f10
f2 or f3 e tubes
https://www.rx7club.com/1st-generation-specific-1979-1985-18/jet-weber-dcoe-612927/
Old Aug 4, 2011 | 09:11 AM
85gr3yFB
thanks!! r those calibrations good for florida driving?
Old Aug 4, 2011 | 06:56 PM
rx71king's Avatar
the diabolical one
it is hot down there...play with the main jets 185 of 190....the best way to no if your engine is happy at all times.is to get a wideband........or just wing it
Old Aug 4, 2011 | 07:11 PM
snivley whiplash's Avatar
brappppp brappppp
+1 on wide band- it was the only I got me dellarto to run good
Old Aug 11, 2011 | 10:06 PM
85gr3yFB
i got wat u said, low and mid rpm power is good but after about 4k it kinda dies off. wouldnt that mean i would have to get larger air corrector jets since they r wat calibrate fuel in the higher rpms? i have one extra 175 air corrector (my other one got bent :/) ill try to get other 175 air corrector and c how those work. how much do wide bands go for and where in the exhaust would u put it and how?
Old Aug 11, 2011 | 11:16 PM
rx71king's Avatar
the diabolical one
like 15 to 20 inches..... this w/b looks cool http://www.glowshiftdirect.com/Tinte...uel-Gauge.aspx you may need to play with your fuel pressure and check the floats height......the search function is your friend...there is tons of info.....
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
sYnth.
Aug 19, 2015 06:27 PM
Clacor
Aug 14, 2015 09:17 AM
