any tricks to replace trans rear seal?
Old Jul 17, 2011 | 08:59 PM
smellycat's Avatar
I got me a leaky rear transmission seal. any thing tricky about it? That 80w oil sure is stinky when it burns s SC
Old Jul 17, 2011 | 09:04 PM
mazdaverx713b's Avatar
Have RX-7, will restore
-remove the exhaust center section or main converter and pipe.
-then remove the underbody heatshield
-remove the driveshaft
-using a seal puller, remove the seal from the trans.
-clean the seal mating surface on the tailshaft
-lube the new seal's outer metal ring with a small amount of trans oil or grease
-using a seal driver or large enough socket or other trusted tool or device, drive the new seal into the tailshaft
-reinstall the driveshaft, heatshield, exhaust, and install new exhaust gaskets.
Old Jul 18, 2011 | 04:42 PM
smellycat's Avatar
Thanks I was wondering (or hoping i did not have to )to pull that heat shield. I guess I do SC
Old Jul 18, 2011 | 05:53 PM
RX-7 Chris's Avatar
also drain the oil from the tranny before you remove the drive shaft.
Monsterbox
Jul 29, 2022 10:48 PM
Th0m4s
Feb 26, 2019 02:04 AM
NoMorePoison
11
Aug 18, 2015 11:18 AM
