Megasquirt required fuel calculations for different injectors?
Old Jul 15, 2011 | 08:59 PM
turbo2SE's Avatar
yeah its a rotary
im about to do a huge fuel system upgrade on both my rx7's
fc with 550 primary and 1600 secondary ms2 extra
fb with 550 primary and 750 secondary ms1 extra
im not 100% how to go about entering in the numbers to calculate for my injectors being so different from stock size. can anyone explain the math for doing this correctly? or do i need to do a staged map for the huge gap between the primarys and secondarys?
Old Jul 15, 2011 | 09:43 PM
Jobro's Avatar
SAE Junkie
Assuming the FC is going from 550cc pri + 550cc sec to 550cc pri + 1600cc sec.
All you do on that car is change the size of the secondary injectors to 1600cc in the staging page. I would also suggest you stage based on duty being at 85% and then use 5% hysteresis.
If you stage in 1600cc injectors when the primaries alone reach 85% you'll still cut back all the way to a new duty cycle in the 20s or 30s of % duty.
Old Jul 17, 2011 | 03:21 PM
muythaibxr's Avatar
MegaSquirt Mod
On ms2/extra, I would suggest using the table-based staging feature. That'll give you the best staging behavior of all the options (so much so that I'm considering removing the other options for ms3).
Ken
Queppa
Nov 18, 2024 03:47 AM
Skeese
65
Mar 28, 2017 03:30 PM
imitek
Aug 28, 2015 05:28 PM
