Umm? Running rich!!
Old Jul 14, 2002 | 09:30 AM
HAILERS's Avatar
HAILERS
On the whole, you did this to yourself. You removed the acv and airpump. All rx will read around .75 volts, give or take, at idle with the engine warmed up. That is normal.
There is a scenario where you will not see approx .75 volts at idle. That is with a fully functional acv and airpump. Even this combination will show high or rich readings if the variable resistor on the 86-88 are turned too far to the rich.
I can go to either of my cars and the 02 sensor will read a minus number or something on the order of .010 etc. If I go to the variable resistor and turn it slowly towards the rich area, the voltmeter will change from the low reading to approx .75 volts. BEfore going for emissions I make sure the idle shows the minus reading.
There is nothing wrong with you car or injectors because it reads rich at idle. YOU caused that by removing the acv and airpump. Not a big deal. Normal. Unless your car is studdering and missing a lot at idle.
Old Jul 14, 2002 | 06:20 PM
HAILERS's Avatar
HAILERS
Yeah, I agree. I was wrong. Is it possible the engine you salvaged the fuel injectors off had some or one injector that was say a 720 instead of a 550? You've already thought of that though.
I have no solution but the one you've already been thinking about..........taking it apart and putting the original injectors back in.
Or you might look at the two injectors that are left out of the salvage engine and look at the numbers written on the side of the connector. Since you have at least one of the primary and one secondary of the original injectors, you might be able to tell what the injectors were i.e. something other than 550's.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Jun 26, 2016 10:21 AM
86glxNA
Aug 22, 2015 08:54 PM
