Tps?
Old Jun 2, 2011 | 12:46 PM
mezarx7's Avatar
"the project"
Tps?
My idle is bouncy.. Tps is at spec.. Could it be bad? Any other suggestions.. Thanks for the time
Old Jun 2, 2011 | 12:49 PM
mezarx7's Avatar
"the project"
Tps?
My idle is bouncy.. Tps is at spec.. Could it be bad? Oh and I have an s4 engine in an s5 n/a's.. Would the timing be different? 89 fc n/a.. Thanks for the time..
Old Jun 2, 2011 | 01:42 PM
RotaryRocket88's Avatar
Top Down, Boost Up
It could. Test the resistance sweep for dead spots. You should also check for vacuum leaks, or leaks at the TID, etc...
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
