Strange Idle
Old May 29, 2011 | 06:47 PM
Nelson Rebelo's Avatar
QC Strange Idle
Hi to all.
My project 1990 Rx7 13B has never idled properly.
Today I started the car and miraculously it was idleing perfectly and purring for about 60 seconds and then started the good old roughness.
Didnt run car for 3 weeks. Its been raining alot lately and humid.
the Oxygen Sensor wire is is ripped from the sensor and was never connected..
Why would it idle well for 60 sec for the first time in months. Sensor was never connected yet, as i have to buy new one. Could it be the weather. I have checked for vacuum leaks and all seems well there.
I know that the BAC valve needs replacing or a good cleaning because when I squeeze the air tube there is no change in idle. (I was told it was a good way to check)
Any clues?
Thanks
Nelson
Old May 29, 2011 | 07:07 PM
RotaryRocket88's Avatar
Top Down, Boost Up
What idle speed was it when smooth? Did it get rough after dropping down as the engine warmed?
95% of idle problems are from vacuum leaks or TPS problems. https://www.rx7club.com/showthread.p...55#post5131155
The 02 sensor is not used at idle; it's only used when cruising at high vacuum/low throttle/low RPM.
Old May 30, 2011 | 09:06 PM
It was about 1400rpm, It actually stalled after 1 minute, when I restarted it it was back to the old rough idle. Never got a chance to warm up.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
