will s5 halfshafts meet up with s4 rear end
Old Jul 11, 2002 | 05:05 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
If i swap out my s4 n/a tranny drive shaft, diff and halfshafts, will it meet up with the hubs? or do i have to get the hub's and breaks too?
Old Jul 11, 2002 | 05:24 PM
HuggyBear's Avatar
id say just swap out the tranny and driveshaft. it should only take a little modification to match up the driveshaft to the rear end if it doesnt bolt up exactly.
i set my 88t2 tranny and driveshaft up to my series 5 n/a rear end. only had to extend the bolt pattern outwards on the differential flange. just a little measuring and drilling and it matched up perfectly.
itl save you tons of hassle and money.
Old Jul 11, 2002 | 05:31 PM
alright, thx
Old Jul 11, 2002 | 11:41 PM
TeamWireRacing's Avatar
If everything is for an N/A, it will match right up.
Old Jul 11, 2002 | 11:42 PM
no, its t2 drivetrain engine to halfshafts, im asking if i have to change my s4 n/a (87) hubs to meat up with the s5 T2 drivetrain
Old Jul 11, 2002 | 11:48 PM
Node's Avatar
The brake/wheel hubs will work.
But you have to have an all Turbo drivetrain (tranny, driveshaft, diff, halfshafts).
Or an all N/A drivetrain (auto tranny and auto driveshaft, or manual tranny and manual driveshaft), but the diff and halfshafts with N/A fit both auto and manual.
I think halfshafts should bolt up fine whether 4 lug or 5 lug, but I am not positive.
Old Jul 12, 2002 | 01:20 AM
ok, good, cus i plan on a t2 swap and was goign to do a brake upgrade later and didnt see the need to upgrade twice
cool cool thax node
Th0m4s
Feb 26, 2019 02:04 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
