Power FC non sequential map
Old May 26, 2011 | 05:11 PM
KrisD1's Avatar
non sequential map
What do I have to change when going non sequential?
Can I use the standard base map and ignition or do I have to change them?
Old May 27, 2011 | 11:15 AM
tom94RX-7's Avatar
You will need to tune the fuel map a little. You may need to add some fuel. When I did it I added a little fuel to the PIM table for boost first and then tuned the fuel map with my wideband dataloging. You don't need to change the timing maps.
Old May 29, 2011 | 10:08 AM
cewrx7r1's Avatar
Eye In The Sky
Since boost buildup below 4000 rpm will be slower, you can increase onboost timing below 4000 rpm.
Detemine the area within the lower left quadrant of the map where your engine goes through when accelerating to column N10.
Add some timing in there for the used P rows from about P11-P20.
2-4 degrees is safe.
Look at the base mod map for that area.
Old May 30, 2011 | 11:13 AM
KrisD1's Avatar
ok, thanks guys ;-)
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
