Power FC base map for 1000/2200 cc ID's ?
Old May 14, 2011 | 07:02 AM
indispeed's Avatar
Hi All,
i just install 1000/2200 cc InjectorDynamics i'm having hard time reving and idleing the car. does anyone good map and don't mind helping me out??.
the mods are stock port , t78, hks twin power, greddy intercooler.
thank you.
andy h
myrx7juss8u@aol.com
Old May 14, 2011 | 09:33 AM
cewrx7r1's Avatar
Eye In The Sky
I assume that you have fully setup all the Settings 5 injector values using a DATALOGIT.
Old May 14, 2011 | 08:37 PM
indispeed's Avatar
yes, setting 5 is already set up, and i'm using datalogit.
Old May 16, 2011 | 04:25 PM
indispeed's Avatar
remember guys, sharing is caring lol.
Old May 16, 2011 | 05:17 PM
the_glass_man's Avatar
Will u do me a kindness?
E85 or Gas? 3 Bar or 2 Bar? I'll have one hopefully in a couple of weeks. You'll have to use some negative lag settings in order to get it to idle correctly. I think a few guys are running ID1000 primaries, maybe they'll chime in.
Old May 16, 2011 | 05:50 PM
indispeed's Avatar
i'm using a gm 3bar map sensor. and i'm trying to get it to run good with pump gas , them i'll fill to up wth e85. I had it running great with the old injector set up 550/1600 but now getting *** kick with the new set up. helpp!!!
Old May 16, 2011 | 06:13 PM
You could try contacting thewird he uses ID1000 primaries with negative lag with his setup.
Old May 16, 2011 | 06:20 PM
indispeed's Avatar
I sent him pm, but no reply.
Old May 16, 2011 | 06:33 PM
Give him some time. I know you're anxious to get your car up and running and believe me nobody knows that more than me as I've been working on getting my car going for over seven years.
Do you have a AFR gauge connected up to your datalogit? Maybe zipping your .dat file and posting it here will give people a chance to look over it. Logs if you have them will help if you've got them.
Alternatively you could try one of BDC's basemaps located here.
http://bdc.cyberosity.com/main.php?g...avId=xe220e554
Also you might want to think about joining Chucks tuning notes group.
Old May 16, 2011 | 07:51 PM
thewird's Avatar
Post your old map.
thewird
Old May 17, 2011 | 07:20 PM
indispeed's Avatar
will do asap
Old May 19, 2011 | 07:33 PM
indispeed's Avatar
how do I forward the maps to this site?
Old May 19, 2011 | 10:12 PM
You have to save the dat file from the Datalogit in a zip file and then upload, unless you can store the file someplace else.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
