what are my options for a direct replacement ECU?
Livin loud like TIMMAAAYY
what ECUs are available that use the factory plugs? are these the best kind? or should a user wired ECU be better?
The Autothority/Tech Tom/GForce chips are all stock modified computers. There is only certain things they can do with fuel and timing. What Ted was refering too was a standalone programmable ECU, such as a Haltech, SDS, Pro EFI ect. THe only "plug in" standalone will be the AEM when it becomes availiable for the FC. Until then i heard someone can make plugin harnesses for the Haltech to the FC, but it was a rumor and the local guy who was gonna get it never got it.
the closest thing that i know of is the www.k2rd.com
adaptor harness. since its a haltech you are on the hook to make the car run
mike
mike
Someone I know will have the WOLF system ready to plug in. It will use all the OEM sensors. It will be a TOTAL PLUG IN.
Read up on the new WOLF 4.0...much better then all that is out there in terms of tunablity and upgradable options. Make sure you also buy a UEGO for tuning and monitoring.
