Thunderhill 2:08 lap
Old Apr 29, 2011 | 03:50 PM
jrx13's Avatar
Went to Thunderhill yesterday and ran a personal best of 2:08.88 on the final lap of the last advanced group session. Lots of traffic throughout the day, but was able to get a good clean lap at the end. Just wanted to share since I'm so stoked! The Hankooks Z214s are amazing! I'm confident there is still time to be had on these tires.
http://vimeo.com/23053112
Old Apr 29, 2011 | 06:44 PM
finger lock's Avatar
Nice lines jrx13!
I think you might pick up a little time if you adjust your gear selection. I'd suggest 3rd gear from T2 entry until T6 exit. Also 3rd for entry of T9 and T10 then 2nd for entry of T11. Your motor wants to sing at high revs...let it!
These are the same gear selections I use when I run Thill in my RX7, as well as the spec Miata guys.
Next time you're up there try it and let me know what you think...
Guy
Old May 2, 2011 | 10:20 AM
jrx13's Avatar
Thanks! I appreciate the feedback!
Up until this last track day, I used to brake and downshift to third in turn 3, stay in third gear until turn 5, then came out of turn 5 in second gear and shift in the middle of turn 5a to third gear. I also used to shift to 2nd gear coming out of turn 11. My car has 4.88 rear gear and 225/45-15s. So by using a gear calculator, 2nd gear tops out at 56mph, 3rd tops out at 82mph using 8000rpm redline. I usually don't go higher since I'm not racing yet. So I was finding I had to brake more for 11 to shift down to second. Now I brake less and just stay in 3rd.
As for turn 2 and after, it's weird, but using the predictive lap timer, I was finding I am gaining time by not going through the down shifts and up shifts! You can see the predictive lap timer working in the video. It's the left display on the Racepak G2X. The right display is mph. So for this run, I stayed in 4th all the way through until turn 5 then shifted to 3rd gear for that one. Watch the video closely and you can see the predictive lap timer showing my gains. Remember this is all based on previous runs throughout the day, which were all done with more downshifting. Interesting huh? I'm always experimenting so next time out I'll try both ways again and see if it was just a fluke.
If you guys don't have a predictive lap timer, I strongly suggest you get one!
Some data points from the logger:
Top speed = 110mph
Max lat g = 1.47 left, 1.80 right
Max accel g = .56 accel, -.93 decel/braking
Previous best lap time = 2:10.9 on Nitto NT01
Old May 2, 2011 | 10:52 PM
gracer7-rx7's Avatar
needs more track time
Nice numbers. The spec miata lap time was just set at 2:07 at the regional race a few weeks ago.
finger lock is on the money on the gearing.
Old Jun 22, 2011 | 09:14 AM
jrx13's Avatar
trying to embed new video....
don't know how...
Old Jun 22, 2011 | 09:42 AM
Brent Dalton's Avatar
Sua Sponte
[ youtube]put link here[/youtube]
Delete the spaces between the [ and the youtube and put your link where it says to
If that doesn't work, post the link and I'll embed it for you.
Old Jun 22, 2011 | 09:47 AM
jrx13's Avatar
It's a vimeo video. I tried [vimeo]link[/vimeo] and I tried the embed code too. Maybe can't embed vimeo?
anyways here we go:
ITS NOT DONE ENCODING YET!!! HANG ON!
http://vimeo.com/25457153
Quick notes:
Last session of the day. It was hot!
First time merging data & video using program called Dashware.
The Miatas in the video both running forced induction.
The gold RX-7 pretty sure has a ported engine.
No 2:08 this day but ran a very low 2:09 for my FTD.
Car was down on power due to the heat. Coolant warning light on means over 210F.
Steering angle sensor is an actual data channel/sensor that I added.
Old Jun 22, 2011 | 10:36 AM
jrx13's Avatar
Ok it's done. Can't edit my previous post. Every forum I go on has different permissions that I'm going to have to start remembering.
Quick notes:
Old Jun 23, 2011 | 08:15 PM
HotRodMex's Avatar
How are you capturing the steering angle? What are you using as a sensor?
Old Jun 24, 2011 | 09:17 AM
jrx13's Avatar
Glad you asked! I made a post here quite a long time ago actually:
https://www.rx7club.com/forum/showthread.php?p=9068618
I have tps & brake on/off as well but didn't yet show those in my first dashware video.
Next goal is to try to add individual wheel speed sensors.
Old Jun 25, 2011 | 09:28 AM
j9fd3s's Avatar
Community Builder
that might not be too bad, if you're lucky the holes for the ABS sensors are there and drilled out
Old Jun 25, 2011 | 10:57 AM
jrx13's Avatar
I'm looking for a set of the ABS rings. I posted a WTB yesterday but no responses yet. I also picked up some radio shack magnets yesterday. Just looking at different things for now. Trying to keep it cheap by using proximity sensors that I have and sourced already.
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
23Racer
Canadian Forum
Sep 18, 2015 11:10 AM
