Microtech Is the lt10 windows 7 compatible?
Old Apr 18, 2011 | 09:24 PM
BUSTN's Avatar
I picked up a laptop dongle but I keep getting a cannot connect to ecu message. I am running a windows 7 os. Any ideas? Thanks!!
Old Apr 18, 2011 | 11:49 PM
abtosway's Avatar
Two doritos, on a stick..
I had the same problem with the dongle and usb to serial adapter. Have you gone into your hardware manager to the adapters properties and selected com port 1? If so all you have to do is select that port in the LT software and should be in good shape
Old Apr 20, 2011 | 05:17 PM
BUSTN's Avatar
I did that and still getting the no connect message?
Old Apr 20, 2011 | 06:35 PM
BLACK MAMBA's Avatar
FD Project
it is compatible with windows 7, make sure that you have the usb adapter driver installed and usb set to com port 1.
Old Apr 20, 2011 | 07:26 PM
BUSTN's Avatar
I did install the driver and the manager says it's working properly. I also did as in the other post says to change to 19200 and turned off the FIFO . I'm stumped and fustrated
Old Jun 12, 2011 | 11:37 PM
taz8924pr's Avatar
taz8924pr
get window xp or 2000
Old Jul 2, 2011 | 03:07 PM
swkiller's Avatar
Daily Used and Abused
make sure you install the driver from the microtech website. that what made mine work
DocHoliday89
Power FC Forum
11
Feb 18, 2018 01:35 AM
turbojeff
Oct 5, 2015 10:50 AM
