Megasquirt Got Rpm no spark
Old Apr 12, 2011 | 08:47 PM
gabs88gxl's Avatar
Retard
Got Rpm no spark
Ok im having a major headache im starting to go nuts. I have rpm on megatune but im not getting any spark. Ive looked through my zeal board ive checked all my wiring my cas. my sheilded wire everything. anyideas
Old Apr 13, 2011 | 01:48 PM
muythaibxr's Avatar
MegaSquirt Mod
If you have RPM, the problem is probably outside the MS. the Zeal board only conditions the CAS inputs.
Ken
Old Apr 13, 2011 | 04:20 PM
gabs88gxl's Avatar
Retard
Ahhh ok ill check out my wiring today. Thanks ken. The weird thing though is when i try to start the car the led for leading d17 flickers then shuts off then a few seconds later it will turn back on.
Old Apr 14, 2011 | 08:42 AM
Aaron Cake's Avatar
Engine, Not Motor
Resistors on the correct side of the LED?
Software settings correct?
If you have a scope, start tracing the signal from the LEDs back.
Oh, if you were loading firmware with the ECU connected to the coils, you may have also burned out the ignitors.
Old Apr 14, 2011 | 01:28 PM
gabs88gxl's Avatar
Retard
ok ill have to check that out aaron. As for the coils i just changed them to good working ones i had in my parts when i booted i unplugged these ones for sure to be safe. i accidently didnt before so thats what i changed them. i have the pullup to the negitive side of the leds.
how do i trace the leds back i only have a volt meter
rgordon1979
40
Mar 15, 2022 12:04 PM
The1Sun
Sep 18, 2015 07:13 PM
localized
Sep 16, 2015 12:18 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
