Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
Intake air temp sensor Microtech NA S5
Old Mar 29, 2011 | 11:14 PM
DAveFC3sNA's Avatar
BP, Itb'ss, 10K Rpm Built
NY Intake air temp sensor Microtech NA S5
Ok so i'm almost done building this S5 6 port NA Using the Mustang Dual throttle body, now my question is, Since the turboIIs have a IAT on the elbow of the throttle body thats where i would normally wire the Air temp sensor (black wire) on the microtech LT-8s Too, but since i'm NA and i'm using the Ported Stock 6port lower (easier to get brake booster and vac lines and coolent lines for winter also) and the Racing Beat Upper to IDA manifold and i'm having a adapter plate from the IDA to Mustang flange made,
Where would be the best spot to put the Intake air temp sensor? closer to the motor or closer to the throttle body? or in-between?
any real input is appreciated
Old Mar 30, 2011 | 01:42 AM
Shainiac's Avatar
For the NA stock manifolds, the sensor is in the "dynamic chamber", the portion between the upper manifold and the throttle body. Anywhere in the upper manifold should work fine. You could even put it in the tubing between the TB and the filter if you wanted. As long as it's not going to be directly effected by heat soak, it should read the same for the most part anywhere in the intake tract for NA.
Old Mar 31, 2011 | 12:21 AM
DAveFC3sNA's Avatar
thanks for your input i was planning on putting it on the upper manifold on the racing beat to ida upper
Microtech
30
Apr 23, 2016 06:37 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
