AEM EMS Area is for discussing the AEM Engine Management System!
AEM can someone post their cal?
Old Mar 14, 2011 | 09:49 PM
zeeshan's Avatar
i keeep flooding my engine i need a cal that will start on 550 primary and 1680 secondaries. can someone help? i tried the one that is under the startup folder. not sure if car isnt starting cause the engine is badly flooded or if the cal is messed
Old Mar 28, 2011 | 09:20 AM
Leonh's Avatar
What I would do is:
Charge the battery, unflood the engine.
Id consider turning batch fire off on the startup settings (Beive it fires all 4 injectors, some one please correct if wrong!)
Flatten the startup fuel and crank for a few seconds at a time, raising the required fuel untill the engine catches. (This is how I got mine going) Let the car come up to temperature then shut it off and start work on the warm startup. From memory you need to take fuel out for the warm startup.
Can't look at my map at the moment as im at work
