will these fit without any rubbing
Old Mar 14, 2011 | 05:55 PM
revhardallday's Avatar
Bang Bang!
18 x 9.0 (5 x 114.3 +20 or + 36
will this size rim fit on my 94 fd3s? if yeas wich tire size should i run?
Old Mar 14, 2011 | 07:08 PM
MR_Rick's Avatar
Planning my come back
I'm assuming this is all around? what tire size? You will need your fenders rolled in the front depending on tire size even with the +36
Old Mar 15, 2011 | 04:38 PM
Rice Hata's Avatar
RX7Club OG
You will need to roll your front fenders to avoid hitting the fender/fender liner. Go with the +36 up front vs. the +20 and depending on your ride height and the road conditions, you should be ok with 255/35 up front/rear or 255/35 front and 265/35 rear.
Old Mar 16, 2011 | 10:07 PM
KD-93R1's Avatar
The other one
Wheels/Tires
Hey Izzy
Whats up bro, new wheels and/or tires I assume. What kind ya got anyway?
With 18" wheels, and I'm gonna assume you wont use any offsets that are not good ones (recommend 18x9.5x114.3+42) I would def go w/the 225/40-18's for the front tires. When I had my Enkie RP01's years ago the had 225/40-18's on the front and never hit the fender lip. Then when I had my VOLKS made I switched to 235/40-18's in the front and they hit the lip, mainly when I hit the dips on the freeway bridges/overpasses/etc.. Also, if I pull into my driveway to fast w/the wheels cut, entrance ways to stores, small bumps, and while getting in and out of the car. No, but really, like mentioned above I would go w/the 225/40's on the front. I run 265/35's on the rear (18x10.5x_____+__).
Any pictures for us???
Old Mar 16, 2011 | 10:20 PM
Miata_mx5's Avatar
Wangan Nasty
With a roll and 245 / 255 short sidewall tire it will easily fit.
Old Mar 19, 2011 | 07:24 PM
gracer7-rx7's Avatar
needs more track time
You will very likely rub. Maybe not going straight but pulling into a driveway or in a turn, you will.
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
