Another "What is it?"
Old Jul 7, 2002 | 03:14 PM
pedalpusher's Avatar
Who can identify where this plug goes, and where the wire attached to it comes from. I found it broken off in the rat's nest while I was putting everything back together. Here are the pix:
pedalpusher
Old Jul 7, 2002 | 03:23 PM
legendr35's Avatar
kinda looks like the O2 plug
Old Jul 7, 2002 | 03:26 PM
BlackR1's Avatar
Meesto Spakaro
looks like the o2 sensor plug. Go look at your downpipe where the o2 sensor is and see if it's disconnected
Old Jul 7, 2002 | 05:24 PM
Does it plug into the o2 sensor, or does the wire end connect to the o2 sensor? When I looked at it on my downpipe, it didn't have anything connected to it, but it felt like a wire might have attached to the tip of it.
pedalpusher
Old Jul 8, 2002 | 02:02 PM
jr's Avatar
jr
That's the male end of the O2 sensor connector. The wire should be connected to the 02 sensor which is screwed into your precat/downpipe. That connects to the female end which is usually attached to the back (firewall side) of the upper intake manifold where the lift hook is attached.
Old Jul 10, 2002 | 12:10 AM
Thanks guys. Sure enough, it's the wire to the o2 sensor. Now I have to figure out the easiest way to get take off the sensor so I can solder the wire back on. Does anyone know what size wrench fits it?
pedalpusher
Old Jul 10, 2002 | 12:33 AM
rx4ur7's Avatar
22MM
