Power FC Speedo moves while idling HELP!
Old Feb 13, 2011 | 12:10 PM
Still_Ridin_Clean's Avatar
Exclamation Speedo moves while idling HELP!
I have a 93 fd and the sppedometerl moves when accelerate in neutral. I recently cleaned up some wires and must have done something... It's driving me crazy
Old Feb 13, 2011 | 12:53 PM
Is this supposed to be connected to something?
Random plug not plugged in?
Theres a relay between the yellow and black wire. I think this is what I disconnected but I'm pretty sure it wasnt hooked up to anything.
Old Aug 29, 2011 | 10:47 AM
Piotrus's Avatar
I have the same problem. Speedo works just like rev meter when car is not moving. I have no idea, what could be a point...
Old Aug 30, 2011 | 11:59 AM
$lacker's Avatar
I had an issue similar to that when I had created a common ground between my wideband and one of the stock ECU ground wires
Old Aug 31, 2011 | 02:38 AM
Piotrus's Avatar
That's the point. I had removed my wideband some time ago and plugged it again. Probably I connected something wrong (...) Thanks!
Old Sep 3, 2011 | 09:00 PM
agent004's Avatar
EGTs of Doom
I have the same problem. I swapped in a used speedo since my odo did not work and this happends. When I put the old one back in it does not happen, so I think it has to do with the speedo itself. It may be getting "noise" from the tach until an actual speed signal is detected.
rgordon1979
40
Mar 15, 2022 12:04 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
The1Sun
Sep 7, 2015 10:21 PM
Enzo1944
Sep 6, 2015 08:57 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
